I did some searching, but really couldn't find anything. I know the answer will vary greatly depending on the chip and other factors, but does anyone know the rough correlation between cpu temp and max attainable speed? We all know lower temps can give you greater stability when overclocked, and can even help you reach higher speeds. But by how much?
I have a Celeron-T 1.2, which is stable up to 1656Mhz. This is at 1.7v, using pretty decent air cooling which keeps it down to 35°C at full load. I'm considering trying chilled water cooling. Lets say I can get that 35°C full load chip temp down to 10°C. Any guesstimates as to how much higher I could take the chip with a 25° cooler core? 1%? 5%? 10%?
