- Dec 24, 2001
modded 404a regassed mach1 with original Baker evap block Bowman1964 at xtremeresources.com did the mods including cap line adjustment. It holds in the mid to high -40s celsius with a load on. This includes a brand new Black Enlight case (upper and lower). The baker block does not need a prommie easy mod kit and none is encluded.enough seal string to do an install.
im awaiting pics atm,its from another forum member at er.com
price is $520 and pick it up as both the seller and i both want no damnage in shipping.
i know the baker block alone is worth $140 with the Bowman designed and made a universal type evap mount for the Baker block, saving the expense of having to purchase expensive Easy mod mounting kits for the different CPU types.
some of the above is copy and pasted from the seller at er.com so if anything dont make sence just say so and i can clear it up.
this is my first phase change unit,i dont have the experiance as many others would have yet.
i could just buy an original mach1 with cases,at the same cost and its new and warrentied.but with the additions to this and being professionaly maintained i think its a better deal,do you?
