If the 44C represents the temperature inside your case, AKA system temp, you need better case ventilation. With better case ventilation, the case temp should run around 2-3C above room temp. If your PC room is too hot, obviously the case will be also and consequently your CPU temp. They are all interelated.
Hoot
