Hello all!
I've been lurking on these forums for the last month or so soaking up all the information i can about OC'ing and in particular OC'ing a P4. I have used the search thread and yes there is a wealth of information about the P4 but i havent seen anyone raise a question about a problem that seems to plague me.
I recently upgraded my friends videocard to a GTX 260 so he gave me the one below, I also installed 6 GB ram (Vista) and a new blu-ray/DVD/CD etc.... player in his compy so he gave me his old parts. I had the p4 in an old compaq that used to be the family computer until we all got laptops. All in all I only had to purchase a new mobo (old one didnt have pci-e) and a hard-drive. This new setup absolutely leaves my laptop and of course old Compaq in the dust however i feel its now limited by the P4.... hence the O.C.
My progress with this is as follows. This is my STOCK CPU-ID configuration and info:
Intel P4 Northwood 2.4B
P4M900-M4 Biostar socket 478 MOBO
2 x 2GB DDR2 PC6400 Crucial Ballistix
PCIe Nvidia GeForce 9500GS
Western Digital 320 GB Hard Drive
And 1 CD/CD-rw and DVD optical drives..... salvaged from my buddies compy so i dont know exact specs/speeds only that they both work and were free
Those are my stats. When i first began to OC i went up in 3 mhz increments. Starting at 133 to 136.....139.....142.....145.....148.
All was well until i hit 148 i was running prime95 and i went to click on the cpuz icon on my desktop when the system froze.
Prime95 hadnt detected any errors and had been running for about 6 mins when it froze. I let the computer sit but it never recovered so i pressed the reset button. Upon doing so when the computer finished posting it told me that a file got corrupted in windows/system32/config/.....(i have the exact text copied somewhere) Anyways i want able to boot into xp.
So i got out the installation CD and tried reparing but that was to no avail. Finally i gave up and tried to completely re-install xp. I didnt get very far as setup kept telling me that my disk was damaged..... So i returned all my Bios settings back to default and i was able to re-install xp.
I tried to OC to 148 again this time setting the VDimm to +.3v for a total of 2.19 on the ram but the same complete crash requiring me to re-install xp.... so my question is............... Is this normal, to have to re-install xp after a failed OC?
Also i have the ram set to auto SPD and im almost positive that i cant adjust my Vcore as ive been unable to find it in my bios.
Another interesting thing i noticed in my STOCK bios config i see : Async PCIE CLK is set at 100mhz... i have the option of going up to 150 but no lower than 100, i keep reading however that this clk should be at 33mhz?
Any other help or suggestions would be gladly welcome!
