just connect two pins to get 1.7 default. that will give you all the voltage options avalible. im not sure if you can get 1.75 default but you can select it
There are three ways to connect VID3 and VID4 pins. 1) Wire wrap them, 2) use a conductive pen (or automotive window defogger repair kit), or 3) use a tiny "U" shaped wire and put this into the correct socket holes (this is the easiest method).
