- Aug 19, 2002
- you cant spell stupid w/out SIU
okay, i just switched out my mobo (kt4 ultra) for one with serial raid. boot up... nothing...
reset... bios loads normaly, except for a message saying "no cpu fan detected" i look, and its working fine. windows fails to load...
reset... same error message. the fan is running pretty slow, i thought, (im using a volcano 9, w/the auto fan speed sensor tucked in right next to the processor)
reset ... same error message.. windows loads normaly, and i even instal the raid driver.. fine, i guessed it was a setup glich or something...
now to check my idle temps... lets see..49.. 49?!?
i shutdown and feel my hsf... ive never felt something that hot coming out of anything but an oven. even the very top of the hs was very warm... i thought, oh no there goes $52.99... but i did away with the sensor, and went to try it again with the fan @ full spoeed...
then i nicked an edge off my cpu.. thats right, a whole corner... well, i might as well try, i thought.
windos loaded normal, and my temps are normal so far (despite a loss of like 5% of the cpu's surface...
ill post pics, but first: why did having the sensor so close to the cpu cause it to heat up so bad? i mean this hsf was so hot, i couldnt hold it for more than a couple seconds...
i think it wasnt making good enough contact, but the sensor is thinner than the cpu is high... plus, how can the hsf get so hot if its not making contact?, and last, why is my XP still alive?
