- Jan 19, 2006
- Florida
Let's make that easier to understand. People are confusing temperature with the rate of transfer of temperature. (heat transfer)
Ivy bridge produces less heat, as evidenced by the low power usage but has a higher temperature than sandybridge mostly due to the TIM used between the die and the ihs.
A report has shown that reseating the ihs will yield temperatures very close to sandy bridge temperatures.
Airport analogy: an airport can be busy because there are many people going in and out. An airport can also be busy because a snowstorm has grounded all the airplanes.
True almost, I dont recomend LAPPING or remove the IHS not worth the risk for a small cooling + return.
The other thing PPL aren't paying attention to is the fact, smaller die heats faster or so i think? and even though the wattage is lower on these as soon as you apply any stress under OC be it running games or programs the watts come up and the heat is on! anyway here is what I found running 4 of these chips on AIR,WATER,SS,DICE and LN2
MY chart in respect to these chips
2 of my (regular) chips run as follows with good temps
4.5 low v AIR
4.6/5.0 low v water
5.0/5.6 SS start pounding v
5.6/5.8 DICE again more v
5.9 up LN2 massive v
My 2 other chips run a better OC and much cooler up to 5.6 after that I dont think any of these chips do well with the heat.
Bottom line want more from your chip easy.....better cooling but for normal use Air or Water a good chip can run 4.5 to 5.2 pending the chip with good temps under stress.
Just my thoughts from running these for soe time now.
