- May 22, 2001
- LONDON, UK
just built a new pc with a 6570k
Do you mean 3770k?
I was not aware there is a 6570k.
Can't boot at 2400, tried everything... Even struggled to get 2200 to do some prime passes. So at moment, it sits at stock speed and timing.
I tried:For 2400 try CL10-11-11 or 10-12-11 1.65V . Since it's hynix, you won't see big difference setting higher voltage than 1.65V on standard cooling. Only voltages that can help will be VCCIO or VCCSA. VCCSA should be fine at stock or in worst case try 1.00-1.05V. VCCIO set to 1.15V or up to 1.20V to try if it's helping.
I tried:
- ddr 1.75V
- 2400 @ 11-13-12-32 2T
- VCCIO 1.20V (auto was something like 0.93V or similar)
- VCCSA: don't have that option in my BIOS everywhere...
Kinda messed up that VCCSA vs VCCIO thing.
Sometimes VCCSA and VCCIO are under 1 option VTT or VCCIO so changing one is also changing other one too. ASRocks P67 had it as 2 options. I didn't try any of their Z77 boards so I don't really know if they changed that. VCCSA is not really important when you overclock for 24/7 use and 2400 should work even on stock.
Best will be if you lower memory voltage to ~1.65V. More won't give you much and some of these chips are getting unstable above 1.7V.
Is that 2400 11-13-12 working ?
Enable extreme voltage option ( 1 or 2 lines above cpu voltage ) and you get up to 1.92V for cpu. Also change bios to latest one ( official or beta, no big difference ).
One more question ... why single channel memory on that screenshot ? If I'm right then you have 2x4GB 2400 kit
This is not for us to decide . Keep temps under 85C stress testing (Im hoping that is what you mean by load and 68C) and push on if you choose. Personally, I would be happy there though.Edit: How high should I clock the CPU? It's a 3570K and it sits at 4500 @ 1.26V, max temp around 68C.
Thanks like I said last night I didnt have time to work the board pressed, now I will run it find everything then go LN2 this afternoon maybe stream it as well.
The memory? I have 4x4 2400 does it really matter if i use one stick or 2 duo vs single? will it increase my scores vs stressing the chip at such high clocks! as I remember loading less is best for extreme high clocking most of the best clockers use 2GB when running for records ect.
Thanks for the help on the board I should have taken a day to run throught the bios and board for settings. I do know what it takes in the settings on this chip to crank up and it just flys!! a goodie.
4.4ghz with an hour prime stable with temps of 72 and 1.28vcore
with the preset for 4ghz I was up to 85c prime stable for several hours, not sure if my current settings will heat up more, not sure the preset vcore
i'm on an antec kuhlor 620
Tried 2400 11-13-12 with 1.70V and 1.75V, wasn't able to boot (VCCIO 1.15V). 2200 booted (stock timing, stock voltage, VCCIO 1.00V) but was unable to pass single Prime test.
Edit: How high should I clock the CPU? It's a 3570K and it sits at 4500 @ 1.26V, max temp around 68C. Cooled by Phobya 3x120 rad.
When you run 2 channel board then for everything except max clock validation you should run 2 sticks. In some situations 3-4 channel boards can run 2 memory sticks because of how memory bandwidth is scalling.
Ivy Bridge memory controllers are much better than it was in SB and can run even 4 sticks without big drop on clocks ( but for tests 4 sticks are of course bad idea ).
