- Jan 12, 2012
Very nice shrimp.
CPU is just asking for 2V .. but the board says nooooo ...
I had max ~6080MHz on SS with FX8120 and it was pretty good chip but I sold it. If I had good access to LN2 and reasonable prices then I would probably keep AMD/FX.
Yepper looking good Shrimpy. Like Woomack says ya think that board could give it the voltage it needs to go full out???
I think this board can make some more as long as CPU will run at 1/2 cores. Switching to 4 cores and some higher load can end pretty bad
My new rig: http://valid.canardpc.com/2tjb3e
I would run an 8 core on only 2 cores just the same as any FX. They aren't any good with all the cores running, we all know that. So in theory the board would hande a 8 core and a 4 core either running only 2 cores fine.
Johan in the second SS are the overclocked settings on the GPU just not showing up?
Impressive numbers Shrimpy and g0dMan thanks you for the new house heater. He lives down the road from me, I stopped by and picked up a couple of the Samsungs myself. He told me you swapped the 8350.
Why keep a slow processer when I can have fast hard drives??
I hear ya, I put them in raid and they're chugging along well.
Now, since I can't seem to get any answers in the gpu section I'll post this for the clowns. For some reason when I swap my 5850 gpu from my Fx 8350/CHV rig to my 4770k/Maximus Hero rig, the 5850 will not overclock worth a damn. It will do 1000/1145 on most benches on the AMD rig but on the Intel I get nothing but driver crashes at anything above 970/1125. I'm running win 7 on both rigs, using the same drivers and afterburner. I've done fresh installs of win 7 2X just to make sure it's not old crap, drivers etc causing issues. I do not think it's a PSU issue. I have not problems running my GTX 580 on the intel rig overclocked and that draws more power then the 5850. I do not have the PCI-e 4 pin moles plugged in on the CHV so not having one on the Hero shouldn't be the issue. IDK where to go with this, I'm at a loss... Anyone?
