i just lapped my HSF (volcano ii) and put some as2 on the die of my duron
thinking id get soem pretty good improvements from an unlapped HS with stock thermal pad
of course i know i didnt do a perfect lapping job and probably didnt apply the as2 Perfectly, but i think i did a good enough job that it would at least perform AS good as my unlapped heatsink
when lapped i used 180,220,320,600,1000,1500, and 2000 grit, it was pretty flat i thuoght
so i cleaned the thermal pad off the die of the cpu and put a small pellet of as2, and stuck the hs on and removed it to see if the contact was adequate, it looked ok so i booted up my machine and ran some 3dmark 2k to get the temps up
they were a tad higher than my unlapped
any explanation or suggestions on lapping techniques, i just used some glass to have a flat surface, i dont really know that much about lapping, didnt think it was complicated
thanks.
thanks.
