- Nov 7, 2005
wow sub-zero wcing and a/c(not to mention cold beer!)
you need to make the cpu block look like a beer can
four4875 said:this is mighty beautiful. how cool does the AC get the mobos ambient air? checked with it closed yet? and how many panes is the top window? it seems like 2 or more would provide better insulative properties, meaning less heat getting inside there.
am i correct to assume that this is just a setup intended for benching, and not daily use? is it gonna stay in the garage / workshop,, or are you gonna manage to get it moved? i wish i had the money to spend for somethin like that, although i wouldnt go near as big and expensive lol... would stick with a daily gamer / LAN rig.
am i gonna see you pullin through on some bench records with this?
those newly acquired skills will come in real handy if you ever need to mod your vapos for SLI blocks.
Are you going to freeze that vid card as well?
also you shold get a all coper water block(not a plastic like one)
what you useing for the chipset?
Gimmpy224 said:0.0 your doing exactly what im hoping to accomplish as far as not having to regas the compressor and what not but being able to make a chiller that will get me temps below 0c
but if what your doing works, ill probably try to accomplish the same (cooling the whole thing)
I just dont want to have to go through all the trouble and work you have to to regas everything and what not.
otherwise I would make a single stage.
Joe Camel said:up and running huh?...WOW
so what kind of "case" temps are you getting?
throw in that pic of the LN you just got
