Alright everyone!
Currently, I'm fine with my system, it's doing the job just nicely, despite being 2 years old. HOWEVER, one small problem remains - it's noisy.
The (appropriately detailed - let's list the noisy stuff!) specs are
AMD Barton 2500+ @ 3200+ Cooled by a Coolermaster Aero 7, with that blower fan. This is the noisy one.
Abit NF7-S, with the chipset HSF replaced by a Zalman silent cooler.
3 Maxtor hard drives.
ATI 9800, stock cooling, stock speed.
Tagan 480watt silent PSU (rated at about 20db, and in fairness, this thing is quiet!)
All housed inside a Thermaltake Xaser 3 case, complete with 5 case fans.
Now, the following fans are on the rheobus which came supplied with the case (you can see the rheobus in the photos below)
- The front two intake fans
- The rear two exhaust fans
- The CPU blower fan
- The top chimney fan.
The PSU takes care of itself, speeding up the fans when it needs, and the graphics card is always going.
Anyway, on with the pics (you know you love them). Apologies for the slightly blurry quality - they're off my cameraphone.
http://blueacid.neosurge.org/DSC01222.JPG
That's the front of the case, with the drive door, and case-front door shut.
http://blueacid.neosurge.org/DSC01223.JPG
The whole front of the case opened. Hmm, grilles.
http://blueacid.neosurge.org/DSC01224.JPG
When the door is shut, that's the gap through which the incoming air has to pass. Can't find any other easy way to get air to those fans, without leaving the front of the case open all day (yeurgh)
http://blueacid.neosurge.org/DSC01225.JPG
This is the chimney exhaust fan. Two layers for air to get through - the metal case, and the plastic trim on top.
http://blueacid.neosurge.org/DSC01226.JPG
The hard drives, nicely turned sideways by Thermaltake, to block almost all the airflow from the front fans. Luvverley.
http://blueacid.neosurge.org/DSC01227.JPG
Overall look. Cable management looks icky, but it's actually quite tidy, with the cables bundled up. Also, CPU fan and passive northbridge cooler.
http://blueacid.neosurge.org/DSC01228.JPG
Top bit of case. Hi2u cables!
http://blueacid.neosurge.org/DSC01229.JPG
Bit of a funny perspective, that's the graphics card right there.
http://blueacid.neosurge.org/DSC01230.JPG
Back of case, showing the grilles over the rear blue LED fans.
http://blueacid.neosurge.org/DSC01231.JPG
Yay, tagan put proper wire fingerguards on! Less noise
Yeah, I know the host is slow, but the hosting is also free
So, OCForums. My main question...
...how can I get this to be a bit quieter. Right now, if i turn down the fans on the rheobus, I struggle to get to sleep with the system on - there's a constant rush of air sound, which I'd like to lose. I'm willing to spend some money (ie, to acquire a new heatsink for the CPU, or Gfx card, for example), but not tonnes!
Cheers for any help or suggestions!
-Blueacid
-Blueacid
