- Jun 12, 2011
Okay, I'm probably going to run 3 GTX 580 3GB cards. I don't want to use water cooling (too much to learn, plus the rig already costs a fortune) and I'm stuck between these two cases for which one will best cool and ventilate the heat those 3 580s will be putting out.
Initially, I expected the HAF 932 to do it better, with its larger fans, and side fan. But I also wondered if the 6 fans on the Lian Li could do this just as well, if not better. They also both have blue LEDs, something I personally like
If you need the links to each case, here they are:
Lian Li: http://www.newegg.com/Product/Product.aspx?Item=N82E16811112261
Cooler Master: http://www.newegg.com/Product/Produ...=cooler_master_HAF_932-_-11-119-213-_-Product
I appreciate your feedback. It would be really nice to get opinions from owners of both cases, if possible.
