- Jul 19, 2006
- UK
I'm planning to watercool my 360, but I'm having trouble finding a waterblock to go on the GPU, as there is a mere 14mm clearance between mainboard and DVD drive. The GPU uses a 478 style mounting (so I'm told).
I hope to use a Corsair Nautilus 500, which uses 3/8" (same as 10mm?) tubing.
If all else fails I can machine a very simple block, but I'd prefer to find one that's small enough, as it will no doubt offer better performance than anything I can make
Any advice or links would be appreciated. Thanks
edit: A lot of people use a koolance block such as this for the GPU, if this helps you get an idea of what I'm after. It's a shame this block uses a mere 6mm barbs, and is probably crap
