Hi guys I am hoping there are some Gurus out there like Silver that read this and can help me out.
All equipment is in sig, for cooling there is 1 80 mm Sunon case fan exhausting hot air an AX-7 on cpu with ASII and a 80 mm Thermaltake Smart fan 2 cooling it.
Temps using MBM 5 with sensor 2 connected to Winbond 2 Diode are showed 48 celcius right after I just finished playing Unreal 2003 for 45 minutes. I was told by other 8K3A users that this gives the most accurate reading of XP cpu temps through the on die thermostat. At idle now system temp is 32 and cpu shows 44 celcius.
I am able to run the chip at 166 fsb using turbo settings in the bios, no other settings or memory timing has been altered. I need 1.8 to run at 166 fsb although I am sure it will do at 1.775. I have left memory voltage at default. I have not run prime 95 for any length of time to test stability yet. I am using 2619 Epox bios and not sure of the 4 in 1's anyone recommend the best or should I just get the latest??
I attempted to run 3D Mark2K1 SE trying to break 10K as I am short 200 pts. When I had an 1800XP in system running at default I with vid card overclocked to 300/300 , 3 D mark ran fine. Nowtrying at 1.744 ghz the first test completes then I get kicked out to desktop. I can not get it to complete , getting a runtime error??? Video card driver is catalyst 2.3 ATI built.
I can run 3D Mark 2K1 SE at default cpu speed and complete it so there must be something holding me up. I am looking for specific settings that should be changed in my bios if anyone can help. I have not tried gaming with UT2003 at 166 fsb with video card clocked to 275/275. I am assuming I have good enough cooling right? I plan to give a go with UT 2003 and vid card at 275/275 to see if it will work.
Just wanna get this system stable.
Thanks
Cisco KId
Thanks
Cisco KId
