- Apr 14, 2011
SO its been a while...i should make a separate post explaining that. for now, i will post this list of stuff i have in mind.
i am currently receiving around 1,600 dollars from ed jones and then receive another 500 or 600 in jan. i wil be using, at max, 910 dollars to build this computer. i will also put 500 dollars into savings that i will only touch when
a" water balloon hits teh fan" moment happens.
COMPUTER IS HERE>> http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=19878072
i must, AT ALL COSTS, keep the computer at 910 or below.
I plan on giving the PD to my sister who plays portal and portal 2 and maybe other steam games. it has a E5200, Geforce 8400, 2gb of DDR2 800, and the motherboard is an asrock g31m-s with a 160gb seagate. she also does some heavy multi tasking sometimes...too much for the P4HT she has right now.
finally i have an old dell, MSI, and HP that use Socket 478. the HP needs a new supply so it can work well again, MSI acts weird, and the DELL needs a new fan, ODD, and HDD. should i recycle these or fix what i can at a low price?
i also found a power supply laying around that makes a strange whining noise. i ignored it and put it in a computer and it worked fine for a while and now its crashing the router every time it comes on the network. shall i replace its PSU also?
and finally i have a server that uses Two Pentium 3 procssors and has three hard drives. 80gb main, 20gb for game server, and 250 gb for storage. i realize that its not exactly fast enough to do server hosting and file transfers fast enough so i plan to use the p3 to run two HLDS servers and then build another server for SRCDS and use it for file transfers as well. i dont want to buy some expensive server stuff off of newegg and plan to use socket 771 stuff instead. unless i find something else that isnt so intense because right now im using an old gateway right now to host my team fortress 2 MVM server and sometimes it lags when there are way to enemies coming in. it has just a 2ghz Pentium 4 with 512mb of ram. i tried the p3 but it wasnt good enough as things would start to lag hardcore.
now (hopfully) that i have explained everything that im going to try and work on, what do you suggest i do? i will do whatever you suggest. ill do whatever you suggest to do to the older desktops i have.
