MBM 5 question???
DoubleJ8
Bremerton, WA
I just downloaded MBM 5 and I have some questions.
1. It is showing the following:
Case Temp
CPU Diode Temp
CPU Socket Temp
The Case temp seems obvoius but, what are the other 2 temps? I have it set up so that the "Case" sensor is hooked to ASUS 2.
the CPU Diode is set to W83L785TS-S Diode but, I have no idea what this is??? It also gives me the option to hook this one up to W83L785TS-S, Asus 3, 4, and custom. Where should this be set at.
CPU Soket is set up an the Asus 1 sensor.
I'm confused. Please help.
archilochus
THE Senior FANMAN
Houston,TX-USA
If your mobo isnt on the list.I recommend you dont try to use it.
It will not display the correct information.Been there done that.:D
THE FANMAN:cool:
