- Apr 22, 2004
- British Columbia
Anyone know how to get Memtest86 working? The readme was a serious P.O.S...
Crash893 said:usually 24 hours is good i think
reason for that
the house will go threw its full thermal cycle
Imo memtest86 for memory and chipset error detection is the best pre os loaded. In windows, nothing has really topped prime 95 for finding "cpu" instability.
If for example, you can run prime 95 all day but as soon as you run 3dmark2001 or play games and your system still crashes, your problem does not lie with the cpu speed. Chances are your FSB is set too high causing problems with AGP or PCI dividers being too far out of spec. If your still having problems with games / 3dmark crashing and your on an Nvidia Nforce 2 or Intel based system that locks the pci / agp your problem lies with AGP having side band addressing enabled or 8X agp enabled. These types of things wont show up with Prime95.
The Trick with benchmarking for stability is to utilize several tests in conjunction with your hardware. There really is no be all end all benchmark, because computers consist of multiple parts that cannot be stress %100 at the same time is basically what im getting at.
my 2 cents..
