And Dino what motherboards have you ever gotten that supplied a 4pin cpu cable for your psu???
the extra 4pin cpu isnt always needed unless your pushing major volts to the cpu. All you need for 100% stable no super duper volts to cpu is the 8pin cpu
^The 4 pin will help (maybe) for LN2 benching. Not even sure with a 6 cores.
It won't help delivering a better quality current.
What are your vcore, cache (freq and voltage) and input voltage settings?
You could set the cache to 4000MHz/1.15v. Should be stable (maybe 1.2v). Will bring a little bit extr aperformance.
What have you tried to get a higher frequency on the core?
Quite straight forward, you should be able to hit 4.5GHz with 1.25/1.3v max. Unless CPU is really a dog (which unfortunately happens sometimes...).
What are your temps on load (Aida64 or any stress test)?
so what i tought was maybe this 4 pin would help ?
