Hello all, when my 120mm fan on D-Tek radiator is running at 2300rpm the idle temp is 41C when its running at 1700rpm idle temp still at 41C what does that mean? does it means that my water temperature is already close to room temperature?
also, i'm using 3/8 ID tube came from my kit....will temperature drop by changing it to 1/2 ID tubes?
thanks
thanks
