to OCF!
If price isn't being considered then, yes, it should work well with an 1100T.
If you're buying it then it's all a matter of what you're going to do with it - but it wouldn't be MY first choice. There are less expensive boards that will overclock just as well and if you're not overclocking then it's serious overkill.
