Sorry, but I do not have any ATI cards. The process should be very similar.
That sounds like a Nvidia file?
You kind of skipped a stepThat sounds like a Nvidia file?
I've seen people on the 3870x2 use the GPU2 client. I've also hit this issue if my shortcut had the wrong "start in" directory.No I grabbed them and had the three installed. If you mean cudart.dll I had it in the folder. Its looking for nvcuda.dll which isn't listed in the walkthrough. Again I'm trying this on ATI hardware. CUDA I'm pretty sure is a Nvidia only deal.
I was confused by this at first also. When they say "multi gpu" they mean that multiple instances can be running.no im meant gpu. 1.07 is supposed to be multiple gpu, i dont see running multiple clients on multiple gpus as multi-gpu if thats what they meant. ow well, time to get folding.
Is that the error you are getting or is that just a general comment?grr, anyway, unstable machine = no go.
I have two inputs on my single 19" LCD Samsung so I should be able to toggle between them.I would suggest you follow the guide and just temporarily use 2 monitors. I had instructions for just one screen, but I couldn't get it to work
Yup yup, that will workI have two inputs on my single 19" LCD Samsung so I should be able to toggle between them.
Looks like a good canadate for the 16x4 slot.Can't beat this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125089
4x shouldn't matter, but you might want to ask around to make sure.
