- Nov 26, 2004
- France, Lyon
It just refuses to over-clock past a mere extra 200Mhz from stock speeds, or more precisely above 2.42Ghz from 2.20Ghz.
First of all, here are my system's specs (also in sig):
X2 4400+
A8N-SLi Premium BIOS 1009 Final
OCZ4002048ELDCPE-K http://www.ocztechnology.com/products/memory/ocz_el_ddr_pc_3200_dual_channel_platinum
ASUS EN8800GTS 640MB
Antec NeoHE 550W
Windows XP SP2
Second, here's my current BIOS settings:
DRAM Configuration:
Timing Mode: Manual
Memclock index value: 400 mhz
Cas latency (TCL) : 2.5
Min ras active time (TRAS) : 5
Ras to Cas delay (TRCD) : 3
Row precharge time (TRP) : 2
Row Cycle time (TRC) : 10
Row refresh cycle time (TRFC) :12
Read-to-write time (TRWT) : 2
Write recovery time (TWR) : 2
1T/2T memory timing : 1
S/W Dram over 4gb remapping : Disabled
H/W Dram over 4gb remapping : Disabled
Hyper transport frequency : 4
Amd K8 Cool'nQuiet : Disabled
Jumperfree Configuration:
Overclock Profile: Manual
CPU Frequency : 220
PCI Express : 100mhz
DDR voltage : 2.7
Chipset voltage : 1.5
HT voltage : 1.20
CPU multiplier : 11
CPU voltage : 1.375 (I think default is 1.350)
PCI clock syncronization mode : 33.33mhz
Alright, right now, with those settings above, I run my 4400+ at 2.42Ghz, that's an extra 200Mhz, which is a low over-clock I know. But it's the only thing I can do apparently, it refuses to go any higher without major instability issues. I tried so many configurations in the BIOS that I cannot count them anymore. I tried HTT at 2x, 3x, 4x, 5x. I tried to set Tcl, Tras, Trcd and Trp at 3-4-4-12 respectively, I tried 2T Command Rate. I also tried the Memory voltage up to 2.8V, Chipset voltage at 1.6, and then the CPU Vcore at 1.4V, and surely some more settings that I can't remember.
All the persons I've asked to on various discussion forums tell me that my X2 should do more than 2.42Ghz before having instability problems. I always though, after my infinite tries, that I had to get over it and accept the fact that my X2 is just a lemon and is just a very bad over-clocker. Then I thought ... maybe the issue is the Memory ? Maybe I set the settings wrong ? I don't even know if my currently used Memory is actually supposed to do any kind of good over-clocks. Then my last thought was regarding the Power Supply, which is a 550W unit, and realized that perhaps it's just a serious lack of juice past a certain frequency and that my newly bought 8800GTS isn't helping my case about power consumption.
The thing is ... before I got my 8800GTS I had a Radeon X1800XL 256MB, a much "lesser" card, and consumed low amounts of electricity, and even with that card I never could OC my X2 past 2.42Ghz. So I told myself that the GTS shouldn't be the direct cause of my OC failures.
Not to mention that my X2's highest multiplier is 11x, if only I had a 12x, 13x and even a 14x multiplier I might have been able to get to higher clocks without touching the FSB much, if at all. That's maybe my Memory's weakness, maybe it can't sustain anything higher than 220 FSB. At 236 FSB, with 11x multiplier I would have around 2.6Ghz speed, but with such settings I can't get past POST (it does POST, but it never reaches the Windows loading window). Really, technically speaking anything I tried above 222 FSB never worked once. And, yes, I also tried various Memory dividers, in fact I tried all of them in the BIOS, to try and isolate the Memory from the equation but no go.
I'm posting all this because I don't quite have the money for a full system upgrade, hence the reason why I chose to get a new GPU instead of the "whole kit". It was well worth it, I get up to 100% performance improvement in my games, but my X2, at 2.42Ghz, is bottlenecking the GTS quite significantly, I get scores in game benchmarks and synthetic benchmarks (SiSoft Sandra, 3DMark, Aquamark, etc) that are lower than what I "could have" with an higher OC on my X2, like some people told me.
Is there anything I might have missed ? Anything I could try ? I am willing to resign forever if I can't OC it higher, until I get a new system perhaps next year, but until then I just hoped I could squeeze a little more performance out of my CPU and could maybe alleviate the bottleneck burden in my games.
Thanks in advance for your time and support guys.
EDIT:
Here's what I tried moments ago (I included my previous settings with "from")...
DRAM Configuration:
Timing Mode: Manual
Memclock index value: 266 Mhz from 400 (I also tried 333)
Cas latency (TCL) : 3 from 2.5
Min ras active time (TRAS) : 8 from 5
Row precharge time (TRP) : 3 from 2
Row Cycle time (TRC) : 18 from 10
Row refresh cycle time (TRFC) : 22 from 12
Read-to-write time (TRWT) : 3 from 2
Write recovery time (TWR) : 3 from 2
1T/2T memory timing : 2 from 1
Hyper transport frequency : 3 from 4
CPU Frequency : 237 from 220 (so I have 2.6Ghz)
DDR voltage : 2.8 from 2.7
Chipset voltage : 1.6 from 1.5
HT voltage : 1.25 from 1.20
CPU multiplier : 11
CPU voltage : 1.4 from 1.375
And these settings did not work.
What happens is the following: The first POST initialization pass (with memory speed indicated, name of BIOS, BIOS version, CPU speed, etc), then a black screen for around a second, and then I see a blue screen (as if it was a famous "blue screen of death") with some text that I don't have time to read (it shows itself for half a second or so), and then it reboots itself.
That symptom occurs for each and every single settings I've tried above 222 FSB (named "CPU Frequency" as you see here in my BIOS), even if I "lower" the Memory speed from 400Mhz to 200Mhz under "Memclock index" and even if I increase the voltage and lighten the timings.
X2 4400+
Antec NeoHE 550W
Windows XP SP2
DRAM Configuration:
Timing Mode: Manual
CPU Frequency : 220
DDR voltage : 2.7
HT voltage : 1.20
CPU multiplier : 11
EDIT:
DRAM Configuration:
Timing Mode: Manual
CPU multiplier : 11
