- Jul 14, 2001
- Edmonton, Alberta
Ok, what the heck is going on. Its really driving me insane.
The problem:
Internet explorer takes 10 seconds per use. That means if you clicked on IE five times to get five dialog boxes open, they would each take 10 seconds to load up. This issue is getting worse and it just started recently after I got all this garbage (Gator software) that installed into my computer without my knowledge.
I no of no solution to my problem. And only IE does this. Normal IE loads in about 0.01 seconds (INSTANT), just a flash but I think there is some sort of timer that makes the computer idle for 10 seconds and wait for something???
OC-Master
The problem:
OC-Master
