Its been awhile since I've been active in these forums. I was running my old system for about 3 years and finally got around to doing an upgrade. So far my i5 2500k cpu on an Asus P8P67 Pro has been overclocking extremely well.
I was amazed to get 4.8GHz at only 1.3v, ran Prime95 stable for 8 hours two nights in a row. ~28c idle, maxed between 64c-74c full load (a little concerned about the 10c temp difference between cores)
I bumped up to 4.9GHz and 1.325v and am now 8 hrs Prime95 stable at that setting. ~30c idle, maxed between 70c-80c full load (again, 10c difference between the same cores as above)
I think this chip could easily do 5Ghz and maybe even 5.2GHz at acceptable voltages but I unfortunately my temps are getting a little too high for me to feel comfortable at those speeds.
I use Coolit Eco CPU Water Cooling System and right now I only have 1 stock fan on the radiator pushing air from outside the case and exhausting out the top 200mm case fan (Case = Coolermaster Haf X) but I'm looking to get two Scythe Gentle Typhoon 120MM 1850RPM 58.3CFM in a push/pull configuration and hopefully that will help lower temps so I can clock to 5GHz and maybe even more.
My settings:
Turbo Ratio - 49
Internal PLL Voltage - Enabled
Load-Line Calibration - Ultra High
VRM Frequency - 350
Phase Control - Extreme
Duty Cycle - T.Probe (also tried extreme but thought T.Probe would help stabilize differences in core temps, doesn't seem to make a difference)
CPU Current Capability - 110%
VCCSA - 0.924
VCCIO - 1.05
CPU PLL - 1.8125V
EIST and C-States enabled (been trying both enabled and disabled, doesn't seem to make any difference so leaving enabled for now)
I had absolutely no luck overclocking my memory speed OR timings so I'm still running memory at stock settings (Corsair CMZ8GX3M2A1600C9 Vengeance 8GB 2X4GB DDR3-1600 CL9-9-9-24 Dual Channel Memory Kit)
Another concern I have is I am getting very low Physics score on 3dmark11 (~5200 performance setting) I tried disabling c-states and it didn't help my score. I think it might be my firewall (Comodo) I found other people having the same issue using this firewall because strangely it seems to limit cpu usage for x64 applications. Haven't found a fix yet, may have to switch firewalls.
I guess I'm posting this so other i5 2500k owners can get an idea what the latest chips are capable of. Any advice or feedback on my settings would be appreciated.
My settings:
Turbo Ratio - 49
VRM Frequency - 350
VCCSA - 0.924
VCCIO - 1.05
CPU PLL - 1.8125V
