- Jun 27, 2002
- San Luis Obispo, CA
My Rig: Winter Project 2k3 [Cascade]
Well I've finally found some time to post these pictures of my rig! Two days before i left for home, from college, Cathar graced me with an email telling me that it was my turn to get a cascade!!! I decided to order a single pass HC, a Mag2, and use my old tygon tubing. I am upgrading from an old Aquastealth water cooling kit, with a simple maze style water block, BIX, and an Aqua Via 1300. The worst part about the whole project was all of the additional costs for the fittings, padding, and proper tools (dremel/drill). One thing I would like to replace is the current tubing or at least clean them out because some sort of film has developed on the inside walls of the tygon. Other than that I am pretty happy with my current setup. I think the stealthed drives are definately cool looking, and i made sure to put in additional tape that allows me to open the drive manually by touching the lower right hand corner of the drive bay. The shrouds were very difficult to bend nicely. I had to pound at it with a hammer and bend it with pliers, it may not look super nice, but it works. From the pictures you'll notice the heatercore is huge. It's about 8 inches deep, and it's so large that i had to take a chuck out of the optical drive housing of the case. Here's my current setup:
Intel P4 2.4ghz @ 3.2ghz <-- need better chip
Epox 4PCA3+ v2.0
Buffalo PC3700 512mb @ 427 Mhz 2-5-2-2
Radeon 9800 Pro @ core 412Mhz / mem 720Mhz
SB Live Value
2 x Western Digital 80 Gb 8mb cache;
1 x IBM Deskstar 40 Gb;
1 x IBM deskstar 30 Gb
(I pray every night my deskstars don’t blow up)
LiteOn 4X DVD-/+R/-/+RW
Samsung Combo 52x24x52/DVD 16x
Case/Cooling
Cascade AMD + P4 conversion plate
Single Pass HeaterCore
+ custom fan shrouds
+ 4 x Sunon 98 CFM
Danner Mag 2
Tygon Tubing / T fitting
Lian-Li PC70
8 x ThermalTake Smart Fan II
1 x PCmods fan controller
2 x Sunbeam fan controller
Epox 4PCA3+ v2.0
SB Live Value
Case/Cooling
+ 4 x Sunon 98 CFM
Danner Mag 2
Lian-Li PC70
