atm i am using a crossover cable to connect pc to pc directly and was thinking of installing a adsl modem/router. the router has a usb interface and a rj-45 interface and can be used simultaneously. so from this, it means that the modem/router connects to my computer via usb and the other through ethernet. would i beable to use the cross over cable to connect the other computer to it or will i have to purchase a cat 5 patch cable??
oh btw, i know i can keep my existing network setup (pc to pc) but the reason for the router is so that i can have either computer connnected to the internet without needing both to be on
thx in advance
thx in advance
