- Nov 21, 2009
- Seattle, WA
That's a damn good fan, good choice.
Before you start OCing to 4ghz immediately though, I really suggest you torture test your CPU at a lower clock first and make sure you can take the heat. The last thing you'd want is that i7 burning up on you and being down $1000 or however much Intel's overpricing those things now. Anyway, I suggest you start with maybe a 10-20% OC, download and run Prime95, and torture test your CPU. Basically what that does is a whole bunch of computing, enough to have all your cores running full 100% for a very long time. Most torture/stress tests can take up to 6 hours, so you'll wanna start one up before you go to bed preferably and check on it in the morning. You can set a CPU temp for your whole computer to auto-shutoff so you don't run the risk of a very costly overheat, and by stress testing beforehand, you're ensuring that it won't happen during some power computing/gaming later.
If you knew all that, sorry, I read the first post, skimmed the rest, and figured maybe I could help. Good luck!
