jqpdev
- Jan 5, 2014
- New York City/US
Hello all...
Its been a long time since I've built a PC. I'm looking for advice on an air cooler for my new rig. I have (or should have in a few days):
- Thermaltake Chaser A71 Full Tower (have already)
- Core i5-4670k Haswell socket 1150 CPU
- Asus Maximus VI Formula (RoG) motherboard
I ordered a Zalman CNPS9900 D/F CPU cooler, but the install is a nightmare and I'm concerned that excessive downward force is needed to mount the heatsink/fan product to the motherboard. The Zalman is already RMA'd. I chose the 9900 D/F because I've been quite pleased with my old CNPS9700 LED in my current rig.
I'm looking for an air CPU cooler that:
- performs well (performance is >= CNPS9900 D/F and >= CNPS9700 LED)
- is relatively quiet
- is relatively easy to install/uninstall (does not require Herculean strength)
- fits the Maximus VI Formula motherboard and Chaser A71 case
- does not block my RAM sockets (currently using 2x G.Skill Rip Jaws X Series)
- does not block my PCIe slots
- is relatively easy to maintain/keep clean
- is <= $80 US (before mail-in rebates or discounts)
The Chaser A71 case manual says that the CPU cooler height must be < 160 mm. The dimensions on the CNPS9900 D/F are 140-L x 110-W x 154-H (mm). The above dimensions are near perfect in regard to not blocking RAM sockets or PCIe slots.
I've avoided water cooling because I don't want to spend the money for an expensive custom water cooling solution and don't want to entertain the management requirements. Pre-built water cooling solutions seem attractive but I don't want the risk of a leak due to product failure (and all products fail eventually). Also, I'm a total newb when it comes to setting up water cool systems. Yes, I'm being very picky.
Here are links to CNPS9900 D/F and CNPS9700 LED product pages, and a link to my build:
CNPS9900 D/F --> http://zalman.com/global/product/Product_Read.php?Idx=607
CNPS9700 LED --> http://zalman.com/global/product/Product_Read.php?Idx=164
My Parts List --> http://pcpartpicker.com/user/jqpdev/saved/3eqt
So far it looks like the T40 Respire, the Noctua NH-U14S, and the Hyper 212 Evo's height are above the limitations of my case. The Noctua NH-D14 blocks RAM slots.
Anyone have suggestions/recommendations for a better cooler?
