doh0000 said:My local AutoZone did not have any window defogger repair paint. They have a repair kit but the liquid color is brown, not silver (also had an adhesive liquid and a cleaning liquid). I wasn't too sure about getting a brown color paint so I balked. It was mentioned above that using a conductive silver pen would not work. Is there any specific reason for that? My local RadioShack has the conductive silver pen in stock. If using the silver paint is the only option, I'd have to order it online.
ps2cho said:That board WILL work for the 1066FSB. It will NOT work for 800FSB. There is NO AGP/PCI Lock.
Goodluck!
doh0000 said:Why not at 800FSB? The default setting is at 800FSB for E4300 & the board works fine at that setting. Do you mean 1333FSB?
Well, today is THE DAY for me to try this mod. I'll pick up the defogger repair kit on the way home this afternoon. Does anyone know the defogger repair paint can be removed if I goof up? Use rubbing alcohol for removal?
atlr said:How did you measure that the FSB is 200 MHz with the pin mod and the BIOS set to 266?
