I was looking at the EK motherboard kit HERE as a possibility for my i7 build. I know I don't need to cool the mobo, but it means I might not need to worry about any fans or tall heatsinks on the motherboard. The X58 extreme uses an aluminum water block, so its a no-go.
How would people feel about that motherboard block going into a loop with an i7 and a 4870x2 (possibly two of them in crossfire)? I have not selected any water blocks yet (though I plan on using 1/2" ID hose), as I know flow is going to be a big deal. I've got an XSPC RX480 (outside on a vertically rotating front door) and RX240 (inside on the back) in my Antec 1200 so far, and I could fit another RX360 in there if I had to as most of my 5" bays are open. 450ml res in the case as well. I can either run two loops with MCP355's or a single with an MCP655.
The machine can make a ton of noise at full bore, but I'd like it to be very quiet at idle. All the fans on it so far are Yate Loon high speed fans on a controller.
