- Jul 15, 2013
ok so i have a xeon w3690 on an X58A-ud3r version 2.0 motherboard socket 1366 and 6 sticks of 4gb ram for a total of 24 gb
so right now im at 4.3Ghz and 1.355 volts on the vcore cpuz reports 1.344 due in part to load line calibration
if i wanna find out what the lowest stable vcore is for my chip at its current overclock how do i do that
do i just lower the vcore one setting at a time and test prime95 to see if it crashes then if it crashes up the vcore till stable?
and if so how long do i stress test in prime95 to see if vcore is stable
keep in mind im only adjusting the vcore no other settings will be adjusted just wanna see how low i can go to get stable so im not using so much power and making so much heat if not needed
