Hello, I was building a new computer today, the second computer I have built, and I decided that I would use the Corsair H75 to cool my CPU, Intel i7 4790k not overclocked. When I installed it I had the thermal compound making contact with the CPU but I realized that I had to reinstall the back plate. Upon doing this, I had a great deal of trouble removing the Corsair Heatsink/pump. As a result, I ended up smearing the thermal paste across the CPU and then I had to reinstall the Heagtsink/pump to the CPU. My computer works fine now but my idle temperatures are roughly between 35 and 38. When I put my computer under maximum load, using Open Hardware Monitor to monitor the temp and Prime 95, my temperature reached 75 to 78 C when I decided to turn it off. This was only after a minute or two. I am using an Intel I7 4790K and a Corsair H75. Is this normal and should I reapply the thermal compound? Also, does this processor tend to run hotter, I had a 3770k that never reached above 50 C
