- Feb 20, 2005
Salutations,
I'm finally getting around to building my new power-tower Super-Rig - heh - after putting together more than my share fro others, and I'm a bit confused about what RAM to buy. I already have most of my HW from the current PC and just need to transfer to the new build parts listed below.
Here's the current build specs.>>
CPU: AMD FX-8350
Mobo: Asus Sabertooth 990FX R2.0
Vid: EVGA GeForce GTX 650 Ti Boost
PSU: OCZ-ZX1250W
I've been Thinking of Corsair ram this go round and I want something with a nice heat spreader and a 2x8GB format for 16GB of RAM, but this issue of RAM timing has me confused again.. I also want to make sure everything goes together perfectly.. So far.. the regular build is very satisfactory.
I was thinking of the Corsair Dominator line with a CMP16GX3M2X1866C9 module set. http://www.amazon.com/dp/B009PV2VMU or a CORSAIR Vengeance Pro CMY16GX3M2A1866C9 http://www.newegg.com/Product/Product.aspx?Item=N82E16820233539
I'll be using this Rig for some gaming ( skyrim ), video (general playback, conversion, etc. ), lots of multi-tasking, remote support and presentation, and a hoard of other things. It will also be supporting the 6 HDDs I already have, 2 burners and possibly a blu-ray, and TV tuner. Power consumption is not really an issue, but reliability and overall longevity, performance is paramount. My last PC was leader of the pack for just over 5 years and is now an equivalent almost 10 years old. So far.. the rest of the parts are Top Drawer Kensington.. as the old expression goes..
I could also do with a rather good Heatsink.. My old PC has an Thermalright XP-90 on it with the universal mount, but I would like one that's a bit better. I've been looking at Noctua, but I don't like their board mount.. I would prefer 4-5 point contact for the bracket.. It all has to fit in an AeroCool Spiral Galaxies case since we are spending the entire wad on the main HW this time, and My's beginning to feel the pinch. I had to cut a hole for a 140mm Noctua int he side of the case near the vid and CPU assembly for extra cooling so we also need to take that into account for new HS upgrades since I obviously can't plug that huge hole very easily. * chuckles *
My main concern atm is the RAM.. I am curious though if my old HS with a new board mounting bracket would actually, temporarily fit the new board as I have never cared fro stock heatsinks and tend to keep.. my PC overclocked at least a bit.
I think that just about covers it folks.. Do please pas on your thoughts and suggestions.. The budget is already a bit tight with the already chosen HW, but we can squeeze a bit mroe.. Please try to keep the price range of the rAM considerative of the prices on the modules above.. Can't go much higher and certainly would, go lower.. I can get everything else at microcenter..
TiA and Namaste...
Q.
CPU: AMD FX-8350
PSU: OCZ-ZX1250W
TiA and Namaste...
Q.
