- Apr 21, 2004
- Ottawa, Canada
it says -1000 for me? lol. can ypu post the actual score?
Your crossfire is not working. I see that you even went to a new OS, so I guess it's not the driver.3DMARK06 said:SM 2.0 Score 3900
SM 3.0 Score 5564
Looking at your score:
Your crossfire is not working. Did you ever fix your driver as we suggested?
Yeah, I ninja-edited because i saw you went to the new OS. Hardware is the next likely culrpit at this point.
All you have to do is disconnect one card and run the test.
Disconnect the other card, then run the test in the same x16 slot.
You will find out if either one is faulty or there is something wrong with the bridge. You do have the bridge pieces in place dont you?
I know sometimes the most simple things are the problem, but I'm not retarded. Thanks though.
I will try the card swapping idea.
Not necessarily just swapping the slots. But running each card by itself in the top slot closest to the cpu while the other GPU is not in the computer at all.
The only way the CPU could be bottlenecking the score is if you have the TLB work around fix enabled. This greatly reduces the first generation Phenom performance (as much as 20%), I have also heard of quite a few problems of people having the work around fix enabled on them without them knowing. Double check BIOs and Overdrive you don't have it enabled.
You have the latest bios?I did not see anything about the TLB workaround in the BIOS.
