- Apr 1, 2004
- Vancouver Canada
Hi Everybody.
I haven't been on here, or playing around with computers much, for the better part of a decade. For whatever reason, I decided to build a new half decent machine, and I wanted some advice on CPU cooling.
I've picked up an i5 6600K, so no included CPU cooler. I'm trying to decide of I should buy a decent air cooler, or buy the parts to use some of my old water stuff.
The machine sits in my living room and is mainly used as a HTPC, but will also be getting used for some gaming. I'd like to have enough cooling to be able to overclock it a bit, otherwise there was no point in getting the K, but I'm not looking to push any limits. Quiet and maintenance free please.
I have some old water cooling stuff, a BIX2 radiator, some decent fans and controllers for that, and a whitewater waterblock. I would need to make up some parts to mount the waterblock but that isn't a huge deal. My old pump is horribly noisy so to get the water system up and running, I would basically be looking at a bunch of labour to build some bits, and the cost of a new pump. Assuming I want it to be on PWM control, and I'm in Canada, I'd guess I am looking at near $150 for this?
How are the current air coolers comparing? It looks like they have gone all nutty with heat pipes and 120mm PWM fans and other fun stuff. Is there any point in going to water for a system like this, or are current air coolers good enough to not bother?
