- Jan 23, 2013
- Oklahoma, US
Alright.. So, after I got my head knocked on straight (I was a little crooked, and thanks to the guys in the watercooling thread I'd posted for straightening me out), I took my soon-to-be-new build back to scratch.. Curious what everyone thinks about it, and any possible improvements that can be recommended.
Asus Sabertooth 990FX
AMD FX-8350
Seagate Barracuda 2TB HDD
Adata SP900 256GB SSD
2x8GB G. Skill Ripjaws RAM
XDX Double D Radeon HD-7870 GHz edition.
Some of the reviews I've seen on the Sabertooth are saying that it's not compatible with the FX series processors without a BIOS flash, via an AM3 socket, or RMAing it back to Asus.. but, my current board supposedly had the same issue with the Phenom II X4's on an AM2+ socket, and it worked fine despite all reports. Any word on if I should worry about it with the Sabertooth?
Also, someone from my watercooling thread had mentioned that the first board I was planning on using (An Asus Crosshair V Formula-Z) wouldn't overclock as easy as I wanted it to. Is the Sapphire better for it? Tips, advice?
AMD FX-8350
