Thanks guys you want to sdee some pics of my new baby??
This is a big case ;D L590mm W210mm H617mm
with 7x5.25" external bays & 12x3.5" internal it eclipses the stacker & Thermaltake Tai-Chi
Have not done any cable tidying yet so please excuse the scruff in the pics:surprised:
1) The 3 CompartmentsTop deck mobo & 5.25" bays. Bottom left 120mm intake fan (Adda AD1212LB-A71GL 72CFM and 34dBa) & 3.5" drive bays (12). Bottom Right PSU compartment with 2x80mm fan mounts.
2) Well vented base Skateboard wheels, Tyres are provided if u want them, i've fitted them. Note brake lever on right side (rear wheel)
Great spacing between hard drives this is a real bonus a 6 drive bay is just that not well i'll mount half the drives to keep some ventilation. Am using std sata leads which reach ok but will need longer when adding further drives.
PSU Rear Panel Is removable & can be inverted or a custom 1 added. By inverting & fitting PSU in top of compartment space is released which may be used for water cooling components.
About only grouse i have with case i'd have liked to have seen a 120mm fan mounting rather than 2x80mm but thats a mod i might try by making a 2nd panel. If using a lot of drives the rear 120mm as an exhaust would match the front 120mm intake.
Mobo Compartment
Mobo Compartment 2
120mm top rear fan is an intake fan with Air duct that is angled down covering cpu, memory & pwmic area. This area is now around 5C cooler than previous case where rear was exhaust with a 120mm front intake(CM4in3 unit) at the same level, which was my previous best.
The Blower above the pci/pci-e slots exhausts air through the mesh above the slots.
Front Connections Sound USBx2 +1394
Front Case
7x5.25" with CD/DVD ROM bezel x 1 ; 5.25 to 3.5 convertor with floppy bezel x 1
so all in all i'm delighted with case has more than enough room 4 all future expansion can handle water cooling with internal 2x radiator possibly 3x if i push it.
Build & design quality is brilliant everything fits perfectly
May use 3 of the 5.25" bays to add
Lian Li EX-34B HDD Bay Black if i want to improve case cooling.
