- Jul 29, 2011
- Buenos Aires, Argentina
That's really good. Anyone have a clue to the ghash equiv of a 280x or 290x?
335-350mh/s per 280x, 400-430mh/s per 290.
It's a good idea...same here (on amd at least)
Just got a 12hs rental, 0.0275 btc with 4100kh/s. Not bad!
How does that even work?
You give them an ssh connection so they set it up??
Or they send you the pool & worker info and you mine for them??
does the rig have to be 100% stable?
what if your stability depends on cgwatcher to keep it running?
do you get paid upfront?
You get feedback from your customers, I provide web monitoring and 100% stability...linux baby
yeah ive heard that complaint, that its very biased towards the renter. that they can just give you bad feedback and short you on the rent.
i could make my stuff more stable, but at a significant hashrate hit. meh
Good 'ol apache2
What if they leave bad feedback? You have to pay them back? or they pay you less?
or that they point you to a high reject multipool (like clever mining), then blame the high rejects on your rig and not the pool
I'd tell them to deal with it.
Reject % of 10% or less is usually but no always unheard of with my internetz
Actually, mining VTC give a very very low reject rate. Just yesterday I saw 48%+ yes, 48%+ rejects mining that Myraid coin.
I guess it also depends on how fast the block time is.
thats what i mean, they will say its your rig causing the rejects. just what ive seen reported on BTCtalk
