- Aug 5, 2002
Alrighty, after coming up on 1 year of my current rig and with nothing really in the light of coming out thats big in the next few months its time to upgrade my system.
Going back to intel this round since the Core 2 Duo is out now but well of course I need a few suggestions.
Harddrives... Well im going with either 250Gig or the 320Gig Perpendicular drives, 3 of them to be exact to setup in Raid 5. Really is there any down side to this? I want redundancy (so I don't have to concentrat on backing crap up constantly) but also want more speed which Raid will help with. I'm coming from 2x 250gig drives (not raided) and use ~50-70% of them at any one time. Decided 2-3x 320gig's in Raid 0
Ram... I want something good, and I will not go back to Ballistix, sorry bad experiance from them. I've had G.Skill in my current rig and love it. Anyways looking for high speed (Think at least PC6400+) in 2x 1gig kit. I will want to upgrade to 4gigs eventually (with vista around the corner and all), and hopfully any experiance with Conroe setups right now and using 4 sticks of ram would be helpful. Decided 2x G.Skill PC-6400 2x 1gig Kits
Motherboard... Not really picky with boards. Asus have worked good for a few people I know, Abit has been my all time favorite with Intel Setups and I love my DFI for AMD rig. Really not sure what to go with, I won't be doing any SLI or Crossfire setup so don't need a board for that. Decided ASUS P5B Deluxe/WiFi-AP
CPU... Well the big choice what CPU. I'm going with either the E6300 or E6600, the E6400 might be an option due to the higher multiplyer. I know the difference is small between caches but he its always nice to have bigger Has anyone noticed any difference between the processors for OC's really? Any heat difference really between the 2mb cache and 4mb cache also? Decided E6600
Heatsink... I don't think mine will fit on them so I need a new heatsink Suggestions are welcome. As you can see I have a XP-120 on a naked Opty 170 so size really has no bother to me as long as it will fit into my case. I have all the fans I need for it so thats not an issue at all either. Decided Scythe SCMN-1000 really due to the fact that Thermalright jumped the price $8 today
Anyways any help at least narrowing things down would be great. I'll probably drop this into the Intel thread later but figured since it was more or less a whole system I'll keep it out of there til I get some things narrowed down a little bit.
As always, thanks in advance, and help me build a nice setup
BTW The wife agreed to me upgrading (holy crap) so I gotta make it count without blowing a huge hole in the wallet but I got ~$1200-1400 to play with, and if I can get 4gigs of ram now that might be sweet as well (less to worry down the road).
Ordered
Ordered
