BenTriskelion
- Mar 12, 2013
- Vancouver, BC, Canada
Hi, everyone!
I am considering specifications for a high end gaming rig that I intend on building in the coming months. This will be my first build, so I would like to get some advice on such things as intercompatibility of the parts listed here, as well as whether they are the best for the purpose simply because they are at the top of the manufacturer's list.
I would also like the rig to be fairly future proof, so if 6 cores (for example) would not presently be used by any game, I would still like to have them if they would be usable, say, in a year or so.
Here are the parts I'm looking at so far;
Case: Corsair Obsidian Series 900D
Power supply: Corsair AX1200i
Cooling system(s): Corsair Hydro Series H100i CPU Cooler
• Would this be sufficient as the only water cooling part?
Motherboard: Asus Rampage IV Extreme
CPU: Intel i7-3970X
• I have heard that an Intel i7-3930K may be a better choice for gaming when overclocking capabilities are considered. Are either of these the best for gaming?
• What would the overclocking potential be with this setup? Or with the i7-3930K?
GPU(s): Asus NVIDIA GeForce GTX TITAN
• What level of cooling would be required to overclock this GPU?
• How much use is 2 or 3 of these GPUs compared to just 1?
RAM: Corsair Dominator Platinum (64 GB DDR3 memory — 8 x 8 GB 240-pin DIMM — Dual / Quad channel — Voltage: 1.5 V — Speed: 1,600 MHz — Latency: 9·9·9·24)
Storage 1: Corsair Neutron Series GTX SSD (480 GB — SATA 6 Gb/s)
Storage 2: Western Digital WD Black HDD (4 TB — SATA)
Thanks for any input!
CPU: Intel i7-3970X
