I have OC to 4.5 and it is stable in prime for 10 minutes. I am using coretemp to monitor to a max of 81C at 1.300v
I have cpuz also running. What do you suggest is my next step to try to get higher? What multiplier and voltage is common with this chip?
I used these settings suggested from a experienced member (except now I have cpu voltage at 1.3v manually)...
Here are some simple settings for the Asus board. Reset to default and follow these settings:
BCLK: 100.0
Turbo Ratio: by all cores
Multi: 45x
PLL Overvoltage: Auto
EPU Power Save: Disable
OC Tuner: Cancel/Off
CPU Ratio: Auto
Speedstep: Enabled
Turbo: Enabled
VRM: 350
Phase Control: Optimize
Duty Control: Extreme
CPU Current Capability: 110%
CPU Voltage: 1.300 v
Offset Mode Sign: +
Offset Voltage: Auto
Adaptive Thermal: Enabled
Active Cores: All
Limit Maximum: Disable
Virtualization: Disable
CPU C1E/C3/C6: Enabled
Make sure to manually set DRAM voltage, timings, and frequency. Good luck.
PC SPECS:
i5 2500K (I forget exact cpu cooler, but it is a good thermaltake)
ASUS P8Z68-V PRO
I forget exact power supply but it was 650w
ASUS GTX 760
ddr3 pc 1600 Vengeance
Specs:
8GB Kit (2 x 4GB)
SPD Latency
9-9-9-24
SPD Speed
1333MHz
SPD Voltage
1.5V
Speed Rating
PC3-12800 (1600MHz)
Tested Latency
8-8-8-24
Tested Speed
1600Mhz
Tested Voltage
1.5V
BCLK: 100.0
Multi: 45x
CPU Ratio: Auto
Speedstep: Enabled
Turbo: Enabled
VRM: 350
Offset Mode Sign: +
Active Cores: All
PC SPECS:
ASUS P8Z68-V PRO
ASUS GTX 760
Specs:
8GB Kit (2 x 4GB)
SPD Latency
9-9-9-24
SPD Speed
1333MHz
SPD Voltage
1.5V
Speed Rating
PC3-12800 (1600MHz)
Tested Latency
8-8-8-24
Tested Speed
1600Mhz
Tested Voltage
1.5V
