Right, I'm reading great reviews on the whole Core X line-up. I was hesitant listing it as Dat Flank mentioned he didn't like the looks of the Air 540 with this being another cube case But figured I'd throw it in the mix too.
The 780T will definitely fit the bill in that case. (pardon the pun)
Don't forget, if you go with the 750T, if I recall correctly, you could fit a 360mm up top and a 360 up front.
Coolant Temperature Minus Ambient Air temperature
System qualification
Less than 5°C - Extreme system
Comprised between 5°C and 10°C - Extreme to High-end system
Comprised between 10°C and 20°C - High-end to Mid-range system
Comprised between 20°C and 30°C - Mid-range to Entry-level system
