After a few posts and a LOT of reading, here's what I'm planning.
Sticking with current i7 920 and EVGA X58 SLI motherboard will overclock once watercooled.
Upgrading graphics to GTX 580 unsure of brand to go for yet. Will be on air for now. Would like the option to go watercooled though so need to check for card that has a block available. Was considering Gigabyte GeForce GTX 580 SOC 1536MB GDDR5 http://www.overclockers.co.uk/showproduct.php?prodid=GX-082-GI&groupid=701&catid=1914&subcat=1812
Sticking with current case CM HAF 932
Now for the fun bit.
Reservoir - XSPC Dual 5.25" Bay Split (for future GPU cooling on second loop)
Rad - Thermochill TA 120.3
Fans - Enermax TB silence
Pump - Laing D5 Solar (22W) (Max 1500lts/hr & 3.7m head)
CPU Block - EK Supreme HF Nickel (But only if they solve the Nickel plating issue)
Tubing - Primoflex Pro 7/16" ID x 5/8" OD in UV Blue
Fittings - EK Compression 7/16" ID in Nickel Black
Fluid - Primochill pure performance clear with silver coil (maybe two for good measure)
Any advice on above is welcome.
For info I am looking for a quality build not a cheap build.
Primarily a gaming rig with dual monitors 1920 x 1200.
I am also looking for high performance along with near silence. I know these are not easy to attain together but they cannot be mutually exclusive given the right build.
1) I intend to fit the 3 x 120 rad in the top of the case. Given the GTX 580 will be air cooled in the first instance, would the fans be better as flowing into the case? Unsure how high my case temperature will be with the GTX exhausting into the case.
2) Need a bit more research on the Rad and Fans setup. Quiet fans and matching Rad. May need more Rad especially once I hook up the second loop to the GPU. There used to be an option to put a stand off shroud at the back of the case with a 3 x 120 rad vertical. Can't seem to find it now.
Anyway thanks for looking.
Gaz
Gaz
