I’ve been building my own PCs for >15 years, but am finally setting up my first watercooled system. My plan (parts are en route) is to use a Corsair 450D with two 2x140mm radiators on separate loops: one shared reservoir and two pumps in parallel. One pump will push to the top radiator, then the CPU (i7 4930K), then back to the reservoir. The other pump will push to the front radiator, then the GPUs (two R9 290Xs) in sequence/serial then back to the reservoir.
My question is really about the fans. I’d definitely like to have the top radiator blowing upwards out of the case (heat rises, dust settles), and in a traditional air-cooled system I’d have the front fans blowing in to maximize air flow through the tower, but I’m a bit worried about saturating the inside of the case with GPU-radiator-warmed air. Given the case’s rear and bottom openings/fan mounts, could I have both radiators blowing out of the case and rely on the negative pressure inside the case to draw air in through those openings?
If I have both radiators blowing out of the case, should I add an intake fan on the rear of the case? Between the front radiator and PSU I don’t expect to have room for a fan on the bottom.
And finally, how bad of an idea would it be to only mount one fan 140mm fan on a 2x140 radiator? I’m planning on putting two fans on each radiator, but just wondering if taking one fan off (less noise, more space) would be catastrophic to the radiator’s cooling capability or not.
