- Nov 24, 2009
Hi,
I would lke to buy a router for better security all around and I read about the GL-AR750S . It seems to tick all the boxes at 65UK pounds.
Just now on amazon a guy left a negative that the router does not deliver on 5GHZ, and uses only one channell.
Are there any rock solid routers that I could use to ride on my phones simcard to gain a fast connection while using my chromebook?
If I went with the purchasing the GL-AR750S, I see it has a USB option and Ive read about LTE Dongles, would using one of them on the GL gain me any speed or does the Sim provider on my phone cap the throughput speed I can get?
If I was in a fix could I access fast WIFI using other IT equipment or must one always pay an ISP to get onto a fast WIFI network at home or travelling?
Berne
Berne
