It's a LED light bar consists of 18 LEDs.
The pictures were taken with 2 cameras. Sony Alpha A-550 and Canon EOS 50D.
An image is only good when there is a good lighting control as a rule of thumb.
Always try to avoid using direct head-on flash which usually yields harsh look outcome.
Here's a couple tips I thought should be mentioned.
A, use 1/2" standoffs or taller so many passthrough hole drilling for cables can be avoided. CPU power cable, audio cable and fan cables can run underneat the motherboard.
B, a tie post is a good to have to securely tie up GPU and main power cable in place. Not only that, it serves as a fan bracket for rams.
C,
Second system active.
I had to make a couple changes due to the multi-card reader's usb cable was a bit short.
Fans swivel over without the need of remounting.
