- May 4, 2011
Well...I've been wanting to replace them anyways, but i digress.
So, One of my intake 120mm fans which were swiped from my old nzxt phantom case finally bit the dust and siezed up on me.
No noise, no warning, just stopped. Tried swapping the connector to verify it wasnt a channel on my fan controller; nope, fan still out of comission.
I'm looking for an orange led fan to replace the set of 3 that is quiet, while sporting good airflow to put my case into a positive pressure.
I have been eyeing these for awhile, but videos really don't do it justice, and they advertise it as being "Red".
https://www.newegg.com/Product/Product.aspx?Item=N82E16835553010
The noise level is absurdly low for the amount of cfm advertised, but I'd like other opinions.
Push comes to shove I'll buy some orange leds and do a bit of solder work and replace the red leds with orange, but I really want to avoid that if possible, mostly due to extra costs of buying the leds. Budget is not very high, which is another reason I ask for help; $15 a fan is steep.
UV reactive orange sleeving is a BIG plus btw.
