- Apr 26, 2001
id like to know if there is a problem on removing the psu upper panel and let it work this way inside the case.
i tried that because my case has no exhaust space to add a fan so removing that panel from the psu would make its fan to work also as an exhauster fan, helping to remove the hot air from inside the case.
is there a problem on doing that?
thanks.
thanks.
