Hello, I need some assistance with OC this MB with Intel I3 and Gskill RAM settings.
I have attached pics of Gskill Ram bay info for all 4 mem bays.
is there a guide or some tips on the settings for this Bios -
disabled UEFI because i am using Windows 7 pro OS.
current settings:
Fixed Cpu ratio - Disabled for now
CPU ratio - 33
CPU Base Clock (1/100MHZ) - 10000
CPU core Current Max (AMP) - 150
Power Limit 1 Value (Watt) - 65
Power Limit 2 Switch - Enabled
Power Limit 2 Value (watt) - 81
Enhanced Intel Speedstep Tech- Enabled
CPU C1E - Enabled
Manual memory System-
DDR3 DRAM Multiplier - Auto
Dram Timing Control - By SPD
Module spec timing - 11 11 11 28 12 208 6 5 6 24
Dram Command Rate - Auto
CAS# Latency (tcl) - 11
Row Precharge Time (tRP) - 11
RAS# to CAS# Delay (TRCD) - 11
RAS# Active Time (tRAS) - 28
Write Recovery Time (tWR) - 12
Row Refresh Cycle Time (tRFC) - 208
Write To Read Delay (tWTR) - 6
Active to Active Delay (tRRD) - 5
Read CAS# Precharge (tRTP) - 6
Four Active Windows Delay (tFAW) - 24
Manual PWM Phase System
Cpu Request Vcore - 1.175v
Cpu Vcore Mode - Spec Voltage
Cpu Vcore Offset - +0.000v
CPU Vcore Fixed - 1.250V
Phase Control - CPU powerstate
PWM Work Frequency - Auto
PWM I-out override - Disabled
PWM thermal report override - Disabled
CPU Vcore Loadline - Enabled
Manual Votage System
CPU PLL - Auto
DRAM voltage - Auto
Vcc SA - Auto
PCH voltage - Auto
Vcc IO - Auto
DDR3 Memory Insight - see pics
current settings:
CPU ratio - 33
CPU C1E - Enabled
CPU PLL - Auto
DRAM voltage - Auto
Vcc SA - Auto
PCH voltage - Auto
Vcc IO - Auto
